record audio composition resolume
elektramia
Post by elektramia »
hello,
quelles sont les démarches à faire pour pouvoir enregistrer le son (positionner sur un layer) de ma composition en m^me temps que mes images?
je finalise un projet,et il me reste que quelques jours...
@plus
elektramia
Re: record audio composition resolume
hello,
i want to record the audio (set in a layer) of my composition at the same time of the video?
i try several things nothing works and i really need to record my sound with my video for a big project
that must be a silly question but i know nothing about sound as a graphic designer
elektramia
it's with the syphon that i want to record the audio ...but i can't?
As far as I know, Syphon does not handle audio. If you want a definite answer, I recommend asking on the Syphon forum.
elektramia
thanks, i will ask them...
