hi resolume.i using resolume well.
now i have two allen&heath xone 1d midi controller and i wanna use two device with resolume.
but i found problem and affort to solve this problem.
when i'm mapping two device,resolume recognizes all nobe is same CC value.
i want to mapped different CC value or make resolume to recognize different device.
how to solve this problem?
i think this is fast way that give different CC value each two xone 1D.
help me~my love Resolume...
Resolume with two Xone 1D
Re: Resolume with two Xone 1D
This can be done by configuring your Xone.
Out of the box, an Xone device will always send the same CC values. So if you connect two, Resolume has no way of knowing which Xone it came from. It's getting the same CC value from both.
So you will need to configure one of the two to send a different set of CC values, and you're good to go.
