I was using AVer on PC to get cinch live video signal and it worked quite well.
Now I've got new Aver Capture M - I can see the live video in AVer interface, but I don't see it in Resolume in SOURCES
thanks for any reply
never thougt of such a workaround, nice point!faderc wrote:I dont know if this is exactly what you mean, but im using an EasyCap to get image from a Bleeplabs HSS3jb to the laptop, EasyCap Viewer software to show the image on the laptop, then CamTwist software to get it into Resolume.
Bit of a pain, but low cost AND effective.
if you have money there are probably better answers...
party on
Cx
Also instead of using Camtwist, you can use VideGlide capture driver http://www.echofx.com/videoglide.html . It was broken with an earlier release of R4, but it seems to be working for the last few versions. I've been an Easycap user since the R3 was in version 1.faderc wrote:I dont know if this is exactly what you mean, but im using an EasyCap to get image from a Bleeplabs HSS3jb to the laptop, EasyCap Viewer software to show the image on the laptop, then CamTwist software to get it into Resolume.
party on
Cx
