problems with max patches triggering past layer 4
mowgli
Post by mowgli »
I'm using the Max patches to trigger clips from Ableton, all fine until I'm trying to trigger clips on layers 6 and onwards in Resolume. Everything is fine if I try to trigger things on layers 1-4 in Resolume but any further and nothing... The Max clip launcher does show what should be playing in the "Currently playing clip nr" but this is not reflected in Resolume. Any thoughts?
mowgli
Re: problems with max patches triggering past layer 4
Post by mowgli »
Ok after more testing it's doing strange things. Now it works with layer 5 but not with 6...
Seems to be working fine here during a quick test.
Perhaps you can use the Vidvox's OSCTestApp ( highly recommended ) to see if the messages are actually sent and received?
http://vidvox.com/rays_oddsnends/vvopen ... _0.2.4.zip
