Resolume and freestyler
DJ Higgumz
I need help on using resolume with freestyler. I don't have the entec usb to dmx, but I have the dmxking ultra dongle http://dmxking.com/usbdmx/ultradmxmicro. right now I think that shouldn't matter because I will be running both software on the same PC. and if not I will just run over artnet via ethernet cable to a laptop with the dmx software. but- how do I add resolume as a fixture in Freestyler? I'm posting the same question in the freestyler forum aswell.
Re: Resolume and freestyler
hi there,
at firts it should be better to run the software on seprate Hardwear because of the performence.
you need to bulid or dowload a fixture for freestyler to use resolume.
artnet works should work fine so you dont need 2 dmx dongels to work with
greats
greats
