Hello. I wonder if anyone else has problems with changing the speed on a video with OSC?
This is what i have tried:
/composition/speed 2.0
/layer1/video/position/speed 0.1
/composition/video/effect1/param1/values 3.0
Nothing happens. A bug? Or is it me : )
Speed change with OSC
Re: Speed change with OSC
I don't know, man. It's not the addresses. Copy/pasted them straight from your post and they work for me...
Thanks. Then its not me : D
I'll check out how its sent... Great to know!
Hi.
I can use OSC to tell Resolume to change composition speed using a slider.
I wonder if there´s a way to tell it to go back/reset to the regular/initial composition speed without using the slider. I just want to push a button. Couldn´t make it happen so far.
Paulo
Paulo
Just let the button send to the same address, but with the value for the default.
For the global composition speed, sending a value between 0 and 1 will set the speed between 0 and 10. So
will set the global speed to 1.
Code: Select all
/composition/speed 0.1 Re: Speed change with OSC
not working. it does nothing : (
after several blind attempts.. it does what want like this
/composition/speed
Value Range
0.1 to 0
makes no sense, right?
/composition/speed
Value Range
0.1 to 0
