Complete noob here, so apologies if this is a dumb question. I have some clips that are very short (1-2 seconds long). They work fine when I manually call them, as the loop nicely, but if I run the Autopilot, it runs them once before moving onto the next.
It there anyway I can force the autopilot to loop the clip a set number of times?
Thanks in advance
Looping clips in Autopilot
Re: Looping clips in Autopilot
+1
for a workaround you can try this
viewtopic.php?t=5239
only think is that longer clips should be set to "start from last point" otherwise they will always start from their beginning
