How do you turn this feature off? As soon as you record a clip it shows up in the fist available spot on the first layer. I would like for that not to happen.
Recorded clips showing up in the deck...
Re: Recorded clips showing up in the deck...
I tried rtfm before posting
I'm afraid that this is not currently possible in Resolume.
ah ok, oh well. Maybe next version?
Now I'm having a problem where only the top left corner of the recorded output is showing. That was occuring at first, then started working, now it's happening again.
Any known fix for this?
using with Dxtory now, problem solved. Also fixes my first issue
