Intel HD4000 question
zechs3
Post by zechs3 »
I am trying to use the HD4000 for the control monitor alone, while a NVidia graphics card drives the projectors.
I have the Projectors/displays routed through the graphics card outputs, and they are working fine, however all processing is being done by the IGP and the Nvidia shows 0% activity.
Is there a work around to get divide up the processing load?
Or do I need to run everything through the Nvidia card.
I know crossfire was not able to share load between cards.
Any input would help, thanks in advance,
Re: Intel HD4000 question
Resolume does all the rendering on the card that has the interface on it, and then copies this texture to all other cards.
So to get the Nvidia to do the work, assign one of the outputs to be your main desktop and control monitor. Use the other outputs and the Intel as outputs.
Counter-intuitive perhaps, but that's computers for you ;)
