what osc template in this video
lonestar
Post by lonestar »
he guys,
have a little question. what is this for osc template in next video:
http://vimeo.com/95834786
with nice clip status message.
thanks
Re: what osc template in this video
It's a custom TouchOSC layout.
It's nothing more than a grid of buttons, 12 rows by 16 colums. Each button sends a clip connect message to the corresponding clip in Resolume ( ie "/layer1/clip1/connect" ).
It's a tedious task to enter all the OSC addresses by hand, but all in all it didn't take me more than 30 minutes.
Sadler
Post by Sadler »
TIP: If you rename touchosc files as a zip file you can edit the XML in a text editor which is probably a LOT faster than doing it through the TouchOSC editor. Therefore, create one button with /layerX/clipX/... and copy it x times as required for your device. Save the file and edit the XML for each layer and clip number.
He2neg
Post by He2neg »
I have one Question :
is there a Libary / List of the OSC comands you can use in Resolume Arena ?
I found this older Topic
viewtopic.php?f=5&t=4226&start=20
but the "manuals" inside the first post aren´t readable for me.
I have to admit i didnt read through the whole Topic so far.
My dream is if someone have allready a Shortcut to some kind of Touch USC & Resolume comand Libary.
~Berlin~
The list of OSC commands that you can use with Resolume is every item in the interface ;)
You can find each and every address by going into Application OSC Map, and clicking on the item you want to know the address for. Resolume will show the address in the bottom left. It will tell you what sort of value it expects, and the range of the values.
http://www.resolume.com/manual/en/r4/co ... ontrol_osc ( scroll down to the Objects paragraph )
Awesome tip! Where were you one week ago? ;)
He2neg
Post by He2neg »
:oops: Tank you Joris.
~Berlin~
