disable output advanced
VjLuper
Post by VjLuper »
hi guys! there is a quick way to disable the output advanced, once you set it?
He2neg
Re: disable output advanced
Post by He2neg »
yes,
in the main menu on the top of your resolume window you can just choose under Output the screen you want to have or the Advance Output.
so its just 1 click.
~Berlin~
And you can also use CTRL-SHIFT-D (CMD-SHIFT-D on a Mac) to disable whichever outputs are on.
VjLuper
Post by VjLuper »
hah! this mean, you cannot use advanced output AND windowed output (I can see why)
thanks
Well, you could think of any slice in a screen as a windowed output. The only big difference is that if you use advanced output the background will be black.
VjLuper
Post by VjLuper »
yep, my problem is: my second monitor is 2048x1152, this mean that when I'm preparing my video and stuff for a 2048x768 projection I use the output windowed in second monitor... and I cannot use advanced output
Yes you can use advanced output. All you have to do is create a slice and size it down to match your composition (or scale it up or down).
In your case it's pretty easy because your comp is the same width as your screen so all you have to do is adjust the slice height to 768.
