switch clip in a slot with effect etc
VjLuper
Post by VjLuper »
Hi guys! let's say I have a clip, and I changed size,rotation and some other property. Or, I apply on that clip a list of effects. Or I did even both.
My question: is there a way to change the clip in that slot, and let this clip inherit all the property/effect from the old clip? (like when you do alt+drag in aftrer effects)?
Re: switch clip in a slot with effect etc
Hi VJ Luper,
yes there is a easy way. Just drag'n'drop the new clip right onto the video tab inside the clip properties right under the Cue Points tab of your old clip.
Enjoy!
VjLuper
Post by VjLuper »
great! thanks
