clip opacity ignored when slice set to ignore layer opacity
Clip opacity gets ignored when destination slice in advanced output is set to ignore layer opacity.
I think this is related to the problem I described in this post (clip opacity issue)
viewtopic.php?f=12&t=11135#p44433
Re: clip opacity ignored when slice set to ignore layer opac
Ah yes. It makes sense that that doesn't work with the current implementation.
We're going to re-examine both layer to slice routing and clip/layer relations for Res 5. We'll tackle this bees' nest as well then.
