OSC Control - what am i missing here ?!
ia_85
Post by ia_85 »
Hello,
Trying to control some simple features but no luck ..
Here is what i checked
port is set to 7000 on Resolume and Touch OSC.
tablet is on the same wi fi network as laptop.
also tried 2 other different OSC app - still no luck.
any ideas ?
thanks
ia_85
Re: OSC Control - what am i missing here ?!
Post by ia_85 »
using android tablet and windows
windows firewall disabled?
TouchOSC and Resolume should work great together so here is a few questions for you:
Is your computer IP address the same as the Host address in TouchOSC?
Is your Port (outgoing) the same in OSC as the OSC Input - Incoming Port in Resolume?
What OSC commands are you using?
theLABVisuals
Post by theLABVisuals »
Was the OSC bundles issue fixed? (I can't remember). Just to be sure, uncheck OSC Bundles as well.
