Leap Motion Or Xbox Kinect??
B3RN
Post by B3RN »
Hello all,
Deciding between a Leap Motion Controller or an Xbox Kinect unit.... Which of the 2 would you recommend/prefer to use? And why?
Does anyone use a leap Motion controller with Resolume? If so, is it simple to setup/map?
thank you :)
MSI CX61, i7-4702MQ, GT820M 2GB, 16GB DDR3, 1TB Samsung 840 EVO SSD
APC40, Midi Fighter Spectra
ReggieUnderground
Re: Leap Motion Or Xbox Kinect??
Post by ReggieUnderground »
You'll have to provide us with a little more info. What are you trying to accomplish?
nomeencuentro
Post by nomeencuentro »
Hey I would like to use LeapMotion as I have it from a friend.
How would the connection? To try it as a Midi controller?
