How to make a parameter jump
DayVeeJay
Post by DayVeeJay »
I have five surfaces that I'm mapping. I'd like to change the X anchor point so the clip jumps from one surface to the next. Right now I'm using Visution's IR OSC SA. It works perfect until the active clip or layer is changed. Is there a way to send OSC data to a specific clip instead of the active clip/layer?
Re: How to make a parameter jump
you can address any clip directly with
/layerN/clipM/parameter
so /layer3/clip12/
would address the clip in column 12 in layer 3
DayVeeJay
Post by DayVeeJay »
Hell yeah! Thanks Raven!
