Very Bad FPS ! LOW Performance On ALENWARE 17
johnjoseph
Post by johnjoseph »
Hardware: ALIENWARE 17
am getting very low fps even in 640*480 composition (QUICKTIME / JPEG 2000)
Single Layer: 40 - 55 FPS
2 LAYERS: 10 -16
3 LAYERS: 6 - 9
4 LAYERS: All Most Stuck ( 2 - 4 FPS)
and in between left down side one Waring appearing "LOW MEMORY", what will be the solution ? so grateful if anybody can help me out
here my Hardware:
PROCESSOR: INTER I7 - 4700MQ CPU @ 2.40GHZ
RAM: 16 GB
64 BIT
80GB SSD, 750 HDD
OS: WIN 7 HOME PREMIUM
DUAL GRAPHICS:
1: INTEL HD 4600 (1 GB)
2: NVIDIA GEFORE GTX 770M (2GB)
SOFTWARE:
AREA 4.1.7
Re: Very Bad FPS ! LOW Performance On ALENWARE 17
I'd recommend you upgrade to 4.1.11 and use DXV codec for all your videos.
He2neg
Post by He2neg »
Oaktown wrote:I'd recommend you upgrade to 4.1.11 and use DXV codec for all your videos.
First do this !!!
Then you can check the Logfiles of Resolume if you use the Right Grafik Engine,
if this all dont solve your Problems make sure all your Engery Settings are correct ( max performance, etc)
then you can ask again ;) and we will think further....
~Berlin~
