Mirror Quad
Kadete
Mirror Quad
Post by Kadete »
Hello everyone!
I'm trying to use Mirror Quad on others layer than the one with the Logos.
The effect works great on composition, but on layer or clip, if the size of the clip is lower than the output, i got a weird result.
How can i manage to work arround this problem?
Thanks, happy valentine
Re: Mirror Quad
you can modify the order of the processing on the clip level
video effects can be dragged after the transform, so it produces different results.
He2neg
Re: Mirror Quad
Post by He2neg »
if you just want to clip fullscreen ;) rightclick / scale to fit comosition // or manuall scale the clip bigger
but first trie the "effect order" maybe there is some bug hidden
~Berlin~
Kadete
Re: Mirror Quad
Post by Kadete »
Edit: Finally understood what you meant ravensc. Thank you!
