crossfader position doesn't get saved in composition
is this a bug or a feature?
Re: crossfader position doesn't get saved in composition
I'm going to go with bug. Or do you think it should be a feature?
well, if it is by design so , then it is a feature.
If You wanted to get it saved , then it is a bug.
I for my part would like to be able to save it.
