Resizeable and/or collapsable layers
subpixel
Post by subpixel »
Screen space is always a problem for the clip layers. Sometimes a huge amount of space is wasted by a layer that doesn't change (eg a mask layer, colour filter or similar), changes infrequently, or changes in a way that you don't need to be able to see it. I use a bunch of layers for special effects, such as a track matte, where one layer typically only ever has one thing in it (a Layer Router source).
Sometimes also the "busy" layers are a long way apart; it would be great to get the things you actively want to see on the screen together as much as possible. Minimising layers or being able to resize any layer height woul be helpful.
lotech
Re: Resizeable and/or collapsable layers
Post by lotech »
Agreed! +1 for layers that can be collapsed to just the file name - and possibly colourised.
psychodalien
Post by psychodalien »
Or maybe grouping layers is a good idea too? Also the option for hiding/showing selected layers - like Adobe Premiere "shy" layers.
adriancuervo
Post by adriancuervo »
+1 to collapsable layers. When I build a live cinema setup I use to creater reference or "event launch" layers that don't need to see when performing.
Zamaroht
Post by Zamaroht »
+1 to this, screen real state is specially a problem with 1366x768 resolution.
