This list contains all the FFGL effects for Resolume we know about at the moment. Most of them are free, some are premium.
Compatible with Resolume 7 (64 bit)
Hybrid Visuals Chaser, Stageflow and Pulse:
https://hybridconstructs.com/shop/
Subpixel Various plugins (windows Only)
https://www.subpixels.com/
William Rood aceFX bundle
https://williamrood.net/new/store/acefx2
Angelo Dvizion's Mapper 2, Maste rFX, Kaleido FX and Change to Color
http://www.dvizion.net/portfolio-category/tools/
Daniel Arnett's 360 VJ plugin turns your world upside down and inside out
https://github.com/DanielArnett/360-VJ
Motus Lumina's GeneraXYZ footage packs with FFGL plugins
https://www.resolume.com/footage/GeneraXYZ2
Juicebar Marketplace with FFGL plugins and other helpful tools
https://get-juicebar.com/
FDVJ Fulldome VJ plugins
https://www.fulldomevjs.com/fdvj/
Plus Fisheye and Ascii
https://raduplus.gumroad.com/l/fisheyeffgl
https://raduplus.gumroad.com/l/asciiffgl
Scratchpole's Starglow effect (Mac only)
https://community.vuo.org/t/starglow-im ... xport/6209
Shady Headstash collection of shaders and Wire example patches ported to compiled Wire patches
https://www.headsta.sh/shop/resolume/all/
Notch Block plugin (Windows only)
https://github.com/notchvfx/notchblock_ffgl/
VFXArtShop different FFGL plugins (Windows only)
https://www.vfxartshop.com/product-category/ffgl
Compatible with Resolume 6 and earlier (32/64 bit)
BigFug fugGlitch, fugFeedback, fugPower and fugScope
https://github.com/bigfug/Freeframe
Subpixel TriTone and AutoMask (windows Only)
Visution Mapio
https://visution.com/
https://williamrood.net/new/vjplugins
Trypta Kaleido (PC only)
http://resolume.com/forum/viewtopic.php?f=5&t=10008
Angelo Dvizion's KaleidoFX, MasterFX and the amazing Mapper
Yochee has been porting some Shadertoy goodness to FFGL (PC only)
https://www.7dex.de/works/ffgl-plugins/
We ported Dani Berio's Fireworks to native FFGL and made it part of the open source FFGL repo.
https://github.com/resolume/ffgl/releases
VJ-Spack-O-Mat Lots of fractally and shiny goodness (all plugins PC Only)
https://github.com/trifox/Spack-O-Mat-F ... .0/release
Plus Fisheye
Compatible with Resolume 5 and earlier (32 bit only)
Visution ClipSA, FaderSA, IR OSCSA, IR Keystone2[3], IR Cosmic Pack
https://visution.com/legacy-products/
Dani, Resolume DropShadow and Fireworks
http://resolume.com/forum/viewtopic.php?t=8506
http://resolume.com/blog/7610
Hybrid Visuals Plexus:
http://www.resolume.com/footage/plexus
Marc Wren sfColorRings, sfSpiderPoints, sfJuniperStar, sfBranches
http://sffreeframe.sourceforge.net/ (careful, these plugins seem to be abandoned)
Oleg Potiy FFGLTriangleMixer (Mac & PC), FFGLVolumeRenderer (PC only)
https://github.com/OlegPotiy/FFGLTriang ... aster/Bins
https://github.com/OlegPotiy/FFGLVolume ... aster/Bins
Lynn Jarvis Spout FFGL, ShaderLoader, ShaderMaker, AutoThreshold (PC only)
https://github.com/leadedge
Chris Korda Triplight
https://sourceforge.net/projects/triplight/
https://github.com/victimofleisure/TripLight/releases
Team Syphon Syphon FFGL (Mac only)
http://syphon.v002.info/
Darren Mothersele Noise, RGB Source, Spiral Source, Underwater Life, Evil, Plasma Ball (all plugins Mac only)
https://github.com/cyrilcode/ffglplugin-examples
Plus Fisheye
So how do I use these plugins with Resolume?
On Resolume 6, drop them in the Extra Effects subfolder in Resolume's folder in Documents. Resolume will load this folder automatically on the next launch.
On Resolume 5 and before, create a new folder called ‘FFGL Plugins’ inside the Resolume folder in My Documents (PC) or Documents (Mac). Copy the unzipped .bundle file (Mac) or .dll file (PC) into that folder. In Resolume, add this folder as an extra FFGL plugin folder in the video tab of the preferences. Restart Resolume and the plugins will be loaded.
Let's try to keep this thread clean, so it stays a good resource. Please post additions and changes as comments below, we will then update the list accordingly.
This is not the place to discuss problems with these plugins. For support, you will have to contact the developer of the plugin directly. This is not the place to discuss FFGL development, there's a separate board for that.
World wide FFGL plugins list
Re: World Wide FFGL plugins list
Nice!
frParameters is so useful!
Updated with Techlife plugin packs.
I can't wait to get my hands dirty with these new plugins. Thanks Joris, and thank you everyone else who worked on these!
Cheers!
Cheers!
Updated with Oleg Potify's Volume Renderer: https://vimeo.com/125336693
Updated with Spack-o-Mat GodRay plugin: http://spack-o-mat.digitalgott.com/inde ... eased.html
Updated with Spack-O-Mat's very tasty SunCircleStylistic: http://spack-o-mat.digitalgott.com/inde ... eased.html
Re: World wide FFGL plugins list
BIGFUG (Alex May) plugins now 64bit and well worth the money!
https://www.bigfug.com/software/freeframe/
