Alphachannel is lost
movebandit
Post by movebandit »
When compressing to DXV3 normal or high Quality with mpeg streamclip on MacOS the Alpha Channel is lost. Resolume shows in the information "with Alpha Channel" but the Background isn´t transparent.....
sleepytom
Re: Alphachannel is lost
Post by sleepytom »
That's the same old StreamClip bug that has been around for ever. It cannot batch convert files and retain the alpha channel - it couldn't do it with DXV2 and it still can't with DXV3
use Adobe Media Converter instead
He2neg
Post by He2neg »
Or if the Background is black use the Automask effect if your machine can get it ;)
~Berlin~
movebandit
Oops. Never heard about that mpeg streamclip bug in batch mode....and never used it before with alpha.Thanks for the hint.....Automask with Black an White elements is not the best solution ;)
SOLVED
