Clip duration in BPM measures, not seconds?
dsquareddan
Post by dsquareddan »
Hi is it possible to set a Resolume generative source length duration in measures and not seconds?
I am using DocOptic's ResGen package, and would like to make use of Autopilot more effectively. I have incoming BPM synced to the DJ Mixer. What I would like is for the clips in a layer to change every 16 bars. This is doable if the bpm never changes with some calculation, but if the bpm changes then the clip duration will not line up with the start/end of every 16 bars.
Alternatively, if there was a way to "trigger next random clip". Like how it is in Autopilot now, except have a clip playing on loop, and when I press one midi button it triggers a random clip in that layer, and then goes back to looping that clip indefinitely until I press Next Random Clip again. Autopilot random seems to only trigger next clip at the END of the current playing clip.
Thank you for any help
Re: Clip duration in BPM measures, not seconds?
This is not possible, but custom durations for the autopilot in seconds, beats or number of loops are on our radar.
