Cant add media files!
masterdrummer
Post by masterdrummer »
Hey guys.
At the moment im am testing resolume avenue.
But i really cant add any media to it.
JPEG works finde. But video wont work. I tried both, .avi and .mov but nothing works.
Can you help me?
- Alex
Re: Cant add media files!
you will not be able to add .avi files
video files should be recoded to quicktime-DXV, if you want to avoid playback trouble.
masterdrummer
So you want to say that the software is completely useless for me because it dont even support any kind of codec?
Sorry, but i cant recode all files every time....
masterdrummer wrote:So you want to say that the software is completely useless for me because it dont even support any kind of codec?
I say that for the best realtime performance you should convert to DXV.
some codecs with keyframed design are not easily decoded when playing backwards,or random, and I presume you would want Resolume to follow your movements in real time.
I think all files which can be played back by quicktime should be playable in resolume, but someone will come and correct me if I'm wrong.
I had some mp4-s i think (h264) I could play, but I essentially use DXV, because the design of it allows for fast jumps, backward playing etc.
edit:
http://resolume.com/manual/en/r4/optimising
masterdrummer
Okay but if that would work, all would be fine..........
But i cant even add any kind, except jpeg, to resolume. If i drag and drop any media file just nothing happens.
i dont care for fast jumps or something like that, i just want to stream different kinds of media to an projector.
He2neg
Post by He2neg »
ok lets see if we can help you.
You started Resolume
you found your video in the explorer / right bottom side of resolume ( source / ... )
Does the Files have a Yellow X their or is a litle preview shown ( still image)?
If yellow X -> Resolume cant handle this file / File is Broken
little preview -> file should be fine to play.
drag / drop if from here to a free space
preview it (press the Name under the Media) [should be played now in the lower screen on the left bottom side]
launch it (press the Video window) ( should be played in the upper screen on the left bottom side)
were exactly nothing happen ?!
~Berlin~
masterdrummer
Ok, i got a big yellow "X" on the files but i really wonder why because with vlc or quicktime i can play them.
And i got a problem with Adobe premiere pro i cant choose the codex DXV.
- Alex
EDIT: And the new problem is that i dont have sound. I tried mp3 and dxv.
He2neg
Post by He2neg »
is quicktime installed in the default place ?
if not reinstall it. That should fix the missing of DXV in adobe,
also DXV should be part of the Avenue, but i also installed the DXV codec manuall a 2nd time.
mpeg steamclip is a good tool to convert files into DXV ( batchlist is possible ( but only without Alpha channel))
But in generall you should be possible to play .mov files in Resolume ( without using DXV)
~Berlin~
masterdrummer
Wow, thanks a lot!
reinstallation of quicktime into the default directory fixed the problem.
If you now can help me with my interesting sound problem you would be my hero!
If i play a clip in resolume it sound like, i dont know a word for that, it just sounds like shit. Sorry for the bad word but i cant discribe it.
Its like you sound driver is broken or something like that.
But it cant the driver cause other applications work fine.
He2neg
Post by He2neg »
sry i dont use sound at all, but i know some places were you can take a look and play a little bit around.
Main Menu / preferences / audio ( buffer size / output ...)
also if you run the Demo version you should here "resolume" in a robot voice if this sound ok then you know at least that the output of resolume in generell is ok.
Enjoy ;)
and i´m happy i could help you at some points.
~Berlin~
