trigger column after current clip ends
dRm
Post by dRm »
hallo dear resolume pros!
I will use Avenue for my artistic PhD about visual rhythm and I have two questions:
1. I want to synchronise Avenue with the midi signal from Maschine, NI
I also receive the midi signal in Avenue but if I set the Clock Input to: Start/Stop the clips will not start. On 'Switch to manual on stop' they do start! Any suggestions on this problem??
2. Is there any way to start a video after the current video is finished? For me it would be the best to trigger a column over midi when ever I want and it would start after the current active column videos are done! Something like Beat Snap after active clip is over would be perfect!!! I actually just need the function that every triggered clip waits with starting till the active clip comes to its end...
thanx a lot!
daniel
system:
Avenue 4.2.1
macbook pro, OS X 10.10.3
dRm
Re: trigger column after current clip ends
Post by dRm »
hey everyone!
because I did not get any suggestion or reply jet I just try it again!
Please anyone any tip for following question:
Is there any way to start automatic a video after the current video is finished? For me it would be the best to trigger a column over midi when ever I want and it would start after the current active column videos are done!
thanx a lot! :roll:
dRm wrote: Is there any way to start automatic a video after the current video is finished? For me it would be the best to trigger a column over midi when ever I want and it would start after the current active column videos are done!
look for auto pilot in the manual, it can trigger clips in the same layer after one ends.
colum-like triggering can be done with a color source or still image:you can set their duration in seconds. make them transparent, or move out from the view and they can trigger a clip in given time.
if you need real column triggering automation, then look at the link in my signature. it could help you with your midi triggering problem too.
