crackling/ processing sound appears when resolume is on
texture1
Post by texture1 »
Hi everyone
was wondering if i could get some help?
I have been running Resolume on windows 8.1. recently I have been playing movies through the system and I have started to hear this crackling/ processing sound in the background. At first I thought it was the audio I had converted, but them i noticed it start up as soon as I opened Resolume. Its Driving me mental. for the sound I usually have a 3.5 mm jack plugged into the green LR, then that go's into the mixer. The cracking/ processing sound stops when I close the program. Does anyone have any Idea how to stop this?
All the best
Sean
texture1
Re: crackling/ processing sound appears when resolume is on
Post by texture1 »
- I start the program up
- Press the clip with the audio
- crackling starts
- then happens every time i click on a button
does adjusting the buffer size in Preferences- Audio help with that?
texture1
Post by texture1 »
Not really, there is a slight change but its still there.
is this a laptop?
are you hearing the noise when another app uses the dedicated graphics?
you could have a ground loop which could amplify the mainboard processing noises, try to unplug the power if ti's a laptop, or tape the ground connector of the PSU cord - Just for the test!
texture1
Post by texture1 »
no its not a laptop, custom built pc.
I have no other apps on while I run Resolume. I would defiantly describe it as a processing type sound.
Can you show us your Resolume audiosettings? samplerate, buffersize and playback device.
Greets
A few questions:
- Are you using a DI box?
- how long is your cable?
- have you tried with a different cable?
- do you get the same issue if you plug a headset in the green port?
- is the audio out on your MB or your enclosure?
