Massive FPS drop on Blackmagic Live Input.
stv_myr
Post by stv_myr »
i have a Massive drop from 150 to 6FPS if i select an Live input from an Blackmagic Decklink miniRecorder.
Does anyone know this problem? i don't have this problem with Arena 4 and OS X 10.10
My Rig:
Apple Mac Pro
OS X 10.11.1
2x2,26GHz Xeon
16GB ECC RAM
512GB 840Pro SSD
1x Nvidia Quadro 4000 2048MB
1x Nvidia GT120 512MB
Arena 5.0.1
Composition Size: 2920x1280
Decklink Input Resolution: 1080p30
Rossnz
Re: Massive FPS drop on Blackmagic Live Input.
Post by Rossnz »
Did you find a solution?
We have a similar problem although not as extreme
dcaiman
Post by dcaiman »
Similar problem. No solution.
Only solution, change Nvidia card model.
This is my post with this problem: Problems with GTX970. Low frame rate.
In a project with 1920 x 1080 resolume 4.2.1 in a osx 10.10.4 shows an output frame rate of 60 fps.
All internal content is DXV3 1080 format.
When active a video signal from a Blackmagic live, the low output frame rate to 19 fps.
We tested several blackmagic with the same result (19fps).
- Studio DeckLink 4K - DeckLink SDI 4K - UltraStudio SDI - Intensity Shuttle for USB 3.0 -
This problem occurs in two different computers.
Mac Pro 5.1 with 16GB RAM and i7 Hackintosh with 4790 K with 16Gb RAM.
If we use two computers in 770 or 680 Nvidia cards and blackmagic live video activated, the output frame rate remains at 60 fps. (nvidia drivers not installed)
Using the Nvidia 770 or 680 cards with Nvidia driver drops the frame rate to 19fps.
Is it a compatibility problem resolume with Nvidia drivers?
mosu
Post by mosu »
dcaiman wrote:Similar problem. No solution.
Is it problem really no solution???
I got the same problem on AMD card
spec:
MBPR15" with AMD R9 M370X(late 2015 model) / Arena 5 / 1 1080p output / 1 1080p dxv3 clip and 1 BMD input are triggered
FPS drop from 60 to 30 since BMD input were triggered.
and FPS even drop to 15 when I attach another 1080p output
I have 4 different MBPR 15" models, 2 are NV card, 2 are AMD card,
they all have obvious FPS drop.
they are all laptop level GPU, but all of them can handle 4 dxv3 1080p clips at the same time without huge FPS drop
SO,
what kind of hardware setup(specs) can provide a stable & smooth result if I need
2 1080p with advance output
2 layers with 1080p dxv3 clip
1 layer with LIVE input
I think this setup is very easy and essential
Thanks for reporting the issue, guys.
We'll take a look and see if we can recreate it.
miek
Post by miek »
I think I've found temporary solution for this issue.
I've tested wirecast's virtual camera out with full HD resolution as a source in resolume (Capturing 1080i50 in wirecast and sending it to virtual camera out). Works on 60fps without any fps drop. I didn't tested latency.
So I think that something wrong with Blackmagic's support in Resolume. It works OK on low resolutions but uses to much CPU on Full HD.
By the way, output to Blackmagic do not works properly too...
Z87PRO motherboard
Nvidia 960GTX
i5 + 8GB ram, SSD
Hackintosh 10.11.6 El Capitan
Blackmagic Intensity Pro 4K
Blackmagic Decklink Duo SDI
Resolume Arena 5.0.0
Wirecast 6.0.5
cvanhoose
Post by cvanhoose »
miek wrote:I think I've found temporary solution for this issue.
Z87PRO motherboard
Nvidia 960GTX
i5 + 8GB ram, SSD
Wirecast 6.0.5
First try updating Arena to the latest release. I can not recreate this issue with any of my machines. MBP AMD + Nvidia. PC AMD + Nvidia
1080i @60
BM thunderbolt express - sdi and hdmi
BM PCIe decklink
miek
Post by miek »
Thank you for your reply
I tried Resolume 5.1.2 with no luck. Maybe I have the problem with hackintosh or motherboard's kexts. Everything worked in windows7.
M
fraktal
Post by fraktal »
Hi All,
We have the same problem. Our idea is, maybe this is az El Capitan problem. We have 2 servers, one is El Capitan, the other one is Yosemite. The Yosemite is working fine, the El Capitan has the problem.
What do you think?
Good configuration:
Titan GTX
10.10.3
Bad configuration:
GTX 980Ti
10.11.6.
miek
Post by miek »
Dear Fraktal,
Is there Nvidia's alternative driver on your Yosemite machine or standard?
M
