screensetup.xml broken
After the power of my Arena Server went suddenly off (while playing a normal set), Resolume didnt started. Only after removing the screensetup.xml, it started again. Problem: The mapping in the screensetup was gone. I´ll post the broken .xml file in a while, just have to uncase the Server to get it
Re: screensetup.xml broken
Sometimes catch same error (screensetup.XML were blank). I think it's no resolume problem, but resolume can at least check it's files, just to avoid crashes.
