help needed quite urgent!..
j3man
Post by j3man »
i am using resolume2 and it has suddenly stopped working! all the functons are there i can drag clips onto the decks but when i try an load a clip into one of the layers there is no response from the output/preview box?!! in the screen settings ithere are no options.. until i click 'apply' then it resets itself but even after selecting an ouput resolution it still does not oupt any video/flash footage!!! i need to resolve this problem v quickly as i require the program for gigs coming up shortly..
ive even tried unistalling and reinstalling the package but is still the same?!!..
[Edited on 11-2-2005 by j3man]
bryandod
try deleting decks
Post by bryandod »
Try deleting or moving your decks. And delete any new freeframes you might have added. It does not delete these by itself if you uninstall it. Both of these have worked for me. Good luck.;)
j3man
Post by j3man »
Just tryed that but still no joy?!.. i dont get why it sundenly stopped workin as i was using it earlier on in the day?! this is a propa shitta i will be abit stuffed if i dont get it back up and running :(
Sense
Post by Sense »
You can't load files in decks you mean? if so, delete all files from the preview folder from the resolume install dir, and try again. (Don't delete the preview directory itself of course)
Sense
j3man
Post by j3man »
Right ive sorted it now... uninstalled - then removed all contents of resolume folder and installed again, resulting in a fully functional peice of software once again! WOOHOO :cool:
cheers people
