Hey awesome people!
I'm trying to configure 2 MIDI controllers at the same time (APC MK2 + CMC-PD).
There's (obsviously) a mapping conflict, so i'm asking if theres a way to have one of the controllers with the key mapping different from another?
Regards
Multiple Midi Controller
Re: Multiple Midi Controller
Why don't you put one midi controller on midi channel 1 and the other on midi channel 2 ?
This way you can use both without conflicts or need to use a midi to keystroke app.
Depending on your OS there's different midi-routing software you can use for routing commands from one controller to another midi channel.
If your midi controller doesn't have a build in function for changing channel that is...
Sam
- HacPRO (Win10/OSX10.13 Render+Mediaserver)
- i9 9900K OC - 64Gb RAM - NVIDIA Titan Xp 12 GB VRAM
- MBP 2018 15" - Livid Ohm RGB - Arturia BeatstepPro - DJTT Midifighter Twister
- Bome MTP - Vezér
Bomes is a cheap and easy way to handle this.
Thanks5AMvisual wrote:Why don't you put one midi controller on midi channel 1 and the other on midi channel 2 ?
