Hi guys im new to this software, i would like to know am i able to use Resolume Arena for normal projection mapping only? i'm trying to do a multi projection mapping with 2-4 projectors each using a different pictures. Can any kind people help me out?
This is my PC specs
Intel Haswell-E Core™ i7 5820K 4.5 GHz with Corsair H100i
Asus Sabertooth X99 Mobo
Asus Strix GTX 980
G.Skill Ripjaws 4 16 GB DDR4-2666 MHz
Dell U2515H
Intel 730 480GB
Fractal Design Define R5
Seasonic X 850W
Windows 10 Pro x64
New to Resolume Arena
Re: New to Resolume Arena
What do you mean by normal projection mapping? What do you think we all use Arena for?
You computer specs look great but some you have an NVidia GPU, you'll need some kind of video processor to map to 4 outputs or more since it can only output to 4 outputs and you'll need a UI.
Super special amazing projection mappings?What do you think we all use Arena for?
MaximilianVII
Oaktown wrote:What do you mean by normal projection mapping? What do you think we all use Arena for?
Sorry sir i think i used the wrong word for it, what i meant was simple mapping on the stage backdrop with image and video on each side. Could you tell me more about the Nvidia GPU? why do i need a video processor? i'm new to mapping.
Your GTX980 is limited to 4 outputs and you'll need one for your user interface so that'll leave 3 available for mapping. But you can always split one or several outputs in sub-outputs using hardware like a datapath X4 for Matrox double or triple head.
There are many threads in this forum on how to expand your output numbers.
MaximilianVII
Ok i will search for the thread on how to expand the output. Another question, for setting up the PC and Resolume all i need to do is plug in the output cables to the GPU ports that is all? i want to learn how to set up the machine and the software
First take a look at the simple setup chapter in the manual. This will show you how you can connect your projectors to your computer: http://resolume.com/manual/en/r5/simpleoutput
Then take a look at the advanced output chapter. This will explain how you can work with multiple screens: http://resolume.com/manual/en/r5/advancedoutput
MaximilianVII
Thanks alot
do you have Edge blending tutorial ?
i bought Resolume Arena 5 today and i want to learn more about it hehe.
In terms of video processor, doesn't the 980 have THREE display ports. I know it's not some super officially adopted 1.5-2k usd "datapath" but this actually does work. http://www.evga.com/articles/00815/
Welcome to the era of dvi is crap.
