Tonight I tried to blend two projectors with 5.1.2 on a PC running windows 10 and couldn't get the slices to blend using the soft edge feature. If I open the same composition and output preset with 5.0.4, it blends fine.
I believe I tried 5.1.1 as well with the same result but I don't remember for a fact as it was a long day!
5.1.2 no soft edge on PC
Re: 5.1.2 no soft edge on PC
I've got two PCs running 5.1.2 on Win 10 with soft edge working as expected.
If you can recreate this problem, could you please contact us directly with the computer specifications?
Heey re soft edging in 5.1.1 i noticed i had to turn the soft edge off then on to regain the settings from before the update. Really not sure if this is related but it was a little er confusing just before show the other day..
