Just switched over from Modul8 and having a hard time getting some basic stuff to work. If I have a an image that is 180x180 and I want to animate it with the fountain effect, for example, it only animates within the 180x180 frame of the image, even if my composition is at 1080. How do I make it so that the image animates at the scale of the composition without effecting the rest of the layers?
Thanks in advance.
Getting small images to animate across the entire composition
Re: Getting small images to animate across the entire composition
Flip the order of the transform and the effects
https://resolume.com/manual/en/r5/effects#render_order
