I'm using windows 10, Arena 5.4.
In the last cople of days i've found that when i've triggered clips in my deck, the horizontal bar which comes up to show a clip is loading stays permanently visible over the clip thumbnail.
The clips are still triggering as normal but the line doesn't go away once the clip has loaded.
This has never happened before.
I'm assuming it's not meant to happen?
Does anyone have any suggestions?
Thanks for your help!
Suzybee
