Stingy sphere axis messed up
mowgli
Post by mowgli »
On the stingy sphere effect the axis rotation appears to be all messed up,
• X rotation is rotating the sphere on the Y axis
• Y and Z rotation both rotate the sphere on the X axis...
Re: Stingy sphere axis messed up
Rotation axes are in object space, not world space. So the alignment changes when you rotate the object. The X axis of the object will be aligned with the X axis of the world if you put the Y rotation at 0.25.
Again, which world axis they rotate around depends on the object's rotation, but yeah, they do seem to be doing the same thing. Thanks for letting us know.
