Hi all,
I'm struggling with this issue where I can't select my Lumiverse in Preferences while the output display is on. I have created and saved a Lumiverse in Advanced Output. I can only select the Lumiverse, and the DMX output works, when the output is disabled.
I'm using:
ArtNet Output w/ Enttec Open DMX Ethernet
Mac OS 10.12.6
Resolume Arena v5.1.4
Lumiverse issue: Can't select lumiverse in preferences
Re: Lumiverse issue: Can't select lumiverse in preferences
You only want to use Output > Fullscreen > Display 2 when you're doing a simple one screen show.
When you are using mixed outputs like projectors and LED strips, assign all your outputs via the Advanced Output.
Thanks, it's working perfectly now. I had the wrong output screen in my Advanced Output
