Arena 6 beta 2 issue
Mesec
Post by Mesec »
Hi Resolume. :D
Thank you for Arena 6, its awesome :D
One thing I noticed, if I bypass a group and try to use it in advanced output, when I assign a slice to that group and turn off the "Input Bypass/Solo" button, I don't get the group output through, it's just black. Also when I click on the bypassed groups name, I don't see a preview.
I've had another wish also for years now, I know you've got your hands full with sorting out the bugs in 6, but please please do consider making a way for us to change the duration time for multiple images simultaneously. I often have to make slideshows with up to a 200 or more images, which I like to have all in one layer so I can manipulate transitions on the spot, and having to change the duration value for one image at a time is extremely time consuming, especially during the show.
Thanks for all your work so far! :)
francoe
Re: Arena 6 beta 2 issue
Post by francoe »
Thumbs up for the issue detection, and for the mass duration change recomendation. :)
Tested the issue on win7.
Mesec wrote: if I bypass a group and try to use it in advanced output, when I assign a slice to that group and turn off the "Input Bypass/Solo" button, I don't get the group output through, it's just black.
this is the same issue described in viewtopic.php?f=12&t=14931&hilit=group+bypass right?
Mesec wrote:and having to change the duration value for one image at a time is extremely time consuming
Yes it can be, for these occasions I use a separate OSC Control software, where I can set a timed auto pilot like behavior for the columns that contain the images. Link is in my signature.
You could make a separate post for this in Feature requests if there is not already one.
