Composition Avenue 4 to 6 bug
Monsieur Nuage
Post by Monsieur Nuage »
Hello,
I have a concern to import my compositions from avenue 4 to version 6.
impossible to load my decks.
Has anyone ever had this problem and how to fix it?
Thank you
Re: Composition Avenue 4 to 6 bug
To import Resolume 4/5 compositions you need to open them through the Composition menu - Open file dialog.
Copying the old composition files to the composition folder won't work.
Monsieur Nuage
Thank you for your quick reply.
I try both possibilities.
It also does not work by loading directly through the interface.
nothing happens .
Monsieur Nuage
ok it's good I found.
you have to load from the interface and then save the project again under a new name.
Thank you for your support
