Crash on Text Effect
Dragonsoulj
Post by Dragonsoulj »
Immediately after I drop the Text Block or Text Animator effect onto a clip, Resolume crashes. Am I alone in this? I'm using Windows 10.
Resolume 6.0.1 for more info.
Re: Crash on Text Effect
were you able to send a crash report?
Dragonsoulj
At the time, I didn't have a chance. When I can be in from of the machine again I will try to. I did also notice the third deck (that is the word, right?) would crash if I switched to it.
Sundayz
Post by Sundayz »
HI,
I have the same problem that you !
Resolume directly crash when i put text source in a layer
On windows 10 too.
Have you solved this problem ???
Alejo_rgb
Post by Alejo_rgb »
Hi i also have the same problem and when i load the Generators tab it also crashes. I have version 6.0.1 rev 6056.
Could it be beacause i dont have a GPU?
Alejo_rgb wrote: Sun Jun 09, 2019 17:20 Hi i also have the same problem and when i load the Generators tab it also crashes. I have version 6.0.1 rev 6056.
It could be because you're using 6.0.1. Try 6.1.3, you can get it from our download page.
