Delay camera input to output
PVHmedia
Post by PVHmedia »
hey guys
i have a project coming up in april where they gave me a challenge. So far i don't have found a solution.
i will get a live camera input on my bmd decklink recorder 4k. What they want is to output that input source with a delay of approximaly 30 seconds. The input will run all day.
The idea is a camera filming people coming into a room and project that camerafeed with delay as people walk around the corner and see on big screen themselfs entering the room +/- 30 seconds ago
Is there any possibility to do that within resolume R6 arena?
Or do i need some external equipment, if yes .. what equipment or software?
Thanx
Greetz PVH
elgarf
Re: Delay camera input to output
Post by elgarf »
If you on win, you can try vMix or OBS (crossplatform), looks like they both have delay feature.
You could try multiple DelayRGB effects.
edit: tried it on my macbook, 9 delayRGB effect with RGB parameters set to maximum I got around 20 seconds delay.
on a 720pcomposition, this was pretty heavy on my mac with occasional stutters.
Decklink to OBS to VLC to NDI to Resolume could work better
syphonspout in TOP (or ndi in TOP) -> Delay CHOP -> syphonspout out TOP (or ndi out TOP) in Touch Designer
Oaktown wrote:syphonspout in TOP (or ndi in TOP) -> Delay CHOP -> syphonspout out TOP (or ndi out TOP) in Touch Designer
I second the TD option. There is a delay in resolume's advance output but it's only good for .1s
Then take a look at this post if you need help routing out and back in.
I've been doing some testing in TD and here is what works great:
syphonspout in TOP (or ndi in TOP) -> Cache TOP -> syphonspout out TOP (or ndi out TOP) in Touch Designer
Set your cache TOP as follows to get a 30-second delay at 60fps:
drazkers
Post by drazkers »
Oaktown wrote:I've been doing some testing in TD and here is what works great:
Second this solution but I would capture inside touch designer instead of capturing in resolume and using spout. It supports the same blackmagic sdk I believe.
