I have 5.14 running on my machine, actually I have multiple machines that I upgraded to 6.01, when I open 6 it runs smooth and quickly and before you know it my mouse jots and the system runs slow...
so I close out 6 and open 5 and everything runs normal... so I went back to 5 for the show but I'd like to run 6... so I bareboned installs on both system and soon as I open 6 after a few minuted mouse starts to jot and systems slows...
also keep in mind im running NO content at this point
any place I should be looking?
Have 5.14 perfect 6.01 not
Re: Have 5.14 perfect 6.01 not
Does resolume ever crash?
Sounds like you have a memory issue, but it's strange that it doesn't happen on 5
Can you give us some specs on all of these machines? Things like operating systems, graphic cards, etc?
5.14 is not perfect. I still couldn't use it because it doesn't have screen mapping for the input mapping on advance mode. I find 5.0.1 as rock solid version and was using it till the release of 6.
I believe you just need to step to 5.1.3 for that. I don't think doing away with the year of bug fixes to 5.0.1 should really be suggested.PERCYJOSEPH wrote:5.14 is not perfect. I still couldn't use it because it doesn't have screen mapping for the input mapping on advance mode. I find 5.0.1 as rock solid version and was using it till the release of 6.
You are right but once or twice 5.1.3 crashed and I really don't want to take a risk when on Live.
