pitch shift
Shamai
pitch shift
Post by Shamai »
is there a way to change the speed without changing the pitch of audio and vice versa
Re: pitch shift
Yes but not directly, load your clip with audio/video twice in different layers, remove the audio from one and the video from the other, and trigger using the column trigger. If you need to isolate the clip, you can always group the two layers.
Re: pitch shift
Shamai wrote:is there a way to change the speed without changing the pitch of audio and vice versa
What you describe is usually called Time stretch(or master tempo on pioneer gear), it's the opposite of pitch shift, where you change the pitch without changing the speed.
If you need the audio and video to be in sync, you could achieve what you need with a third party pitch shift vst plugin.
Yes, pitch shift. so you'd change the clip speed in Resolume, then correct the pitch with the effect back to original. This way you get a time stretch effect.
Shamai
Re: pitch shift
Post by Shamai »
where can i get a plugin to do this
is it something resolume would consider for a feature build
Re: pitch shift
