How to manually assign a midi note to a clip
7thheaven
Post by 7thheaven »
How do I manually assign a midi trigger note file in resolume arena? So i can assign it in pro tools?
Re: How to manually assign a midi note to a clip
https://resolume.com/support/en/midi-shortcuts
Set up midi input in preferences, to receive input from the device you send your notes to in ProTools.
Then go to Shortcuts,
Create a new shortcut preset in the Shortcuts panel's dropdown.
Click on the clip you'd like to map, and send a note from ProTools,
click on the next clip you'd like to map, and send a different note from ProTools.
Repeat for as many clips as you'd like with different notes.
Exit mapping save composition.
And if you manually want to assign a note, go into Shortcut mode, right-click on the clip and select Create MIDI Note shortcut.
