External FFT doesnt work after update
Deckard
Post by Deckard »
Hi, external FFT stopped working after latest update. It worked fine before.
We just had a workshop with Arena for 10 people yesterday and i did not work on any computer with the latest version.
Arena just does not react to any internal or external microphones.
drazkers
Re: External FFT doesnt work after update
Post by drazkers »
Deckard wrote:Hi, external FFT stopped working after latest update. It worked fine before.
What happened when you downgraded?
Deckard wrote:external FFT stopped working after latest update.
Which version are you using exactly?
PC or MAC?
Do you have the External Audio FFT input selected in preferences?
Deckard
Post by Deckard »
It happened on PCs and Macs as well. It works fine in older versions. For example on my computer - PC - it worked just fine, after latest update it does not work. All set well in preferences, it just does not react on any sound. I am gonna try downgrade and let you know.
Deckard
Post by Deckard »
OK, so I was using 6.0.5. and everything worked fine. After upgrade to 6.0.6. external FFT stopped working. I can see my windows microphone in the preferences, but Arena wont react on any sound, when I set external FFT on any asset.
After downgrading back to 6.0.5. it still doesnt work.
It works on Arena 5 on the same computer just fine.
Please send us a screenshot of your Resolume 6 Audio Preferences.
