Best Motherboards and Graphics Cards
Stonegate
Post by Stonegate »
I am building a 3 resolume PC's with single 1080 cards and Blackmagic or Magewell Pro capture cards. I am curious if anyone has experience with motherboards that are consistently reliable . I am considering the new 8700k processor so I would need z370 chipset but I also was cirous if the 99 series boards are better.
xdjxklusivex
Re: Best Motherboards and Graphics Cards
Post by xdjxklusivex »
Stonegate wrote:I am building a 3 resolume PC's with single 1080 cards and Blackmagic or Magewell Pro capture cards. I am curious if anyone has experience with motherboards that are consistently reliable . I am considering the new 8700k processor so I would need z370 chipset but I also was cirous if the 99 series boards are better.
In the two machines I have built and used I ran a MSI z170a Gaming M5 board with a 6700k, decklink duo 2 and gtx1070 (this is now my home machine). The setup I am using right now is running a Gigabyte z270mx board with 7600k, decklink duo 2 and gtx1070.
No issues with either setup. Kicking myself for going with the 7600 instead of a 7700 or another 6700 but it still works good.
I'd upgrade the SSD and GPU, But in terms of a MOBO and CPU combo, Here's my 2 cents:
______________________________________________________________________
Thread Ripper X399 Build: $2,629.27
AMD Ryzen Threadripper 1950X - $899.99
https://www.newegg.com/Product/Product. ... gnorebbr=1
ASRock X399 Taichi - $339.99
4 x 8GB G.Skill Ripsaw V DDR4 2466 - $363.98
Noctua NH-U14S TR4-SP# Fan - $159.80
Arctic Silver 5 Thermal Compound - $4.79
iStarUSA D-400-6-Blue 4U Rack Chassis - $164.99
(2) Cougar CF-V12H Case Fans - $24.18
MSI GeForce GTX 1060 GAMING X+ 6G 6GB - $355.65
(2) Samsung 850 Evo 500GB Sata SSD- $315.90
i9 Extreme X299 Build: $2,595.01
i9-7900X - $969.99
ASRock X299 Daichi - $289.99
Cooler Master RR-HD92-28PK-R1 - $53.56
i7 Extreme X99 Build : $2,105.03
i7-6850K - $655.99
ASRock X99 Extreme4 - $199.99
4 x 8GB G.Skill Ripsaw V DDR4 2400 - $329.98
samuelmancebo
Post by samuelmancebo »
Hello, i need to build an Arena Media Server for a fixed installation, it is going to be connected to two LED processors each at 1080p, and also capture card (blackmagic quad) that can support up to 5 input simultaneously. Most of the time will be 6 layers playing, 1 Background and 5 live feeds.
Here is the question, budget is not a problem, but is arena going to be stable enough to be always on and playing live feeds? We also need to make some preset layouts to have different screen options.
I don't know if i am in the right topic but help is really appreciated.
Sorry for the english i am a spanish speaker :?
