Dual Display(please help fast)
Andy_
ill_
i had that problem as well.
you have to clone the displays and then change the secundary screen as first display, reboot your pc and then extend the desktop(the second display) and put it at 1024x768. Then execute resolume, it would start at the primary display, but then you just have to press Ctrl+Alt+2, it puts resolume on the second display (this one is ready to support the resolume desktop resolution). And the output you just have to press Crtl+Alt+1 and to maximize Crtl+Alt+M.
That works with my card, gforce 2 MX400 winfast.
Good luck!
Good luck!
