Artnet Port owned by Resolume at any time!
Andres^C4^
Post by Andres^C4^ »
Hey guys
I have this anoying issue
Many times im using vvvv & Resolume, or Jinx and Resolume, and vvvv and jinx are being used to send DMX over Artnet... the problem is that Resolme is using the artnet port (6454) all the time.
If I disable the artnet out / in from resolume, still I have the same issue.
After resolume is open, I can open jinx or vvvv, but if I do it the other way arround, the 2 program crashes because the post is being used from Arena.exe
Re: Artnet Port owned by Resolume at any time!
To be Art-Net compliant, we need to send an Artpoll request and reply on port 6454, even when we have no outputs and inputs enabled yet. Basically, you always need to let other Art-Net devices know you're there, just with 0 inputs and 0 outputs.
I don't know why VVVV or Jinx would crash when we open the port. We open it in non-exclusive mode, which means that multiple programs should be able to access it. This is also why it works as expected when you open Resolume first. Have you contacted VVVV's and/or Jinx's support yet?
