Error using gl_FragCoord in FFGL
tobetchi
Post by tobetchi »
FFGL plugin using gl_FragCoord load failed on Resolume 6.
For instance, Based on AddSubtract (FFGL example of Resolume), rewrite it for the following.
Code: Select all
static const std::string fragmentShaderCode = STRINGIFY(
uniform sampler2D inputTexture;
uniform vec3 brightness;
void main()
    vac2 p = gl_FragCoord.xy;
    gl_FragColor = texture2D(inputTexture, gl_TexCoord[0].st);
Resolume's AddSubtract example
https://github.com/resolume/ffgl/tree/m ... ddSubtract
tobetchi
Re: Error using gl_FragCoord in FFGL
Post by tobetchi »
Sorry for my typo.
I'll be looking good lint tool for glsl.
francoe
Post by francoe »
So, you're looking for a tool to fix the vac2 mistake?
What about a tool that tells you p is unused and unneeded? ;)
