anyway this might not be a solution for every one but it might just help you out
poss capture card problem solutions
unj_
if anyone is haveing problems with resolume beta 2 vid capture then i might have a possible solution, what i've found is that if it was working in version 1 and not in beta 2 then make sure you have both versions instaled, go into the version 1 and set the capture setings up in that version, now close it down and boot up beta 2, and hay presto your capture "might" be working as if by magic, (just drag the capture card into a box) it might not work for you but it cirtainly has on mine after several days of hair puling and gnashing of teeth, you should note that every time you re-boot or switch of youll have to repeat the prosess
