Premiere / DXV playback
Digitrevx
Post by Digitrevx »
Was wondering if anyone has had the issue where DXV will not play back in premiere or seem to even encode. But is a option as a codec to render with in the export settings. Alley plays my DXV files ok, and so does quicktime.
Digitrevx
Re: Premiere / DXV playback
Post by Digitrevx »
Well I managed to fix it. It required uninstalling my entire adobe master collection and re-installing. I'm not sure what broke but uninstalling premiere alone wasn't enough.
rajatonvimma
Post by rajatonvimma »
hi,
have suddenly the same problem with AE / Premiere CS6. How to fix it?
pax pax
rajatonvimma
ok,
deleted the Resolume DXV folder from:
C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore
and its working again...
sorry.
pax pax
a-li-ce
Post by a-li-ce »
Got suddenly the same issue yesterday.
I use the Adobe CS6 suite.
By updating Resolume with the DXV export plugin for Adobe, I lost the possibility to import the DXV files into Premiere and After effects, but was still able to export them.
I have now deleted the Resolume DXV Files folder there also: C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore .
And it works, I can import and export again.
Maybe it can help Adobe CS6 users ;)
